Originally Posted by ger21 Yeah, the specs on the website are old. Should say Win2K, XP or Vista. Mach3 will even run in Windows 7 beta. 1Ghz is minimum recommended for 25Khz kernel speed. Higher kernel speeds should have 2Ghz or better. Integrated video tends to work OK on most PC's built in the last 2-3 years. Older than that and you may or may not have problems.
I've seen lots of posts from people over the years that saw much better smoothness and consistency when upgrading to a 1.6Ghz or faster from a 1Ghz or less PC. |
A new computer with integrated video on the motherboard shouldn’t be a problem. Simply add a video card to one of the open expansion slots and depending upon the card and of course how much you are willing to spend for it memory will not be a problem. You will still be limited by the system bus speed however.
