Old 06-08-2009, 01:13 PM
juergenwt juergenwt is offline
juergenwt is on a distinguished road
twocik - Advise. As mentioned before. Pick up some books and start reading.
If you want to keep everything solid metric you will have to use a standard metric thread. I do not know the OD of your thread, but depending on the OD needed you will need to stick to the metric thread that is close to it. The same goes for the pitch.
There is no table since the two systems are completely different.
If you need 20 treads per inch you will have to stick with standard inch thread.
