Jonas,
No problem sharing it. It's a very simple testpart. As you can see I made a finishcut with a surface mill sequence because I can't select "4-axis" in a finish sequence. Why isn't that possible since it's the most used 4/5axis milling sequence?
It seems you are working in a company while using MFG, do you have a big database for cutting parameters and tools? I always got problems with uploading parameters in mfg.
Larry,
unfortunately I don't have direct access to PTCU but if you have a link or something which can help me I can get access via my work. I know it's possible to link a coordinate_system to different operations.
Thanks for helping me.
Bart |
