Graham, We doubt that you actually own an Excitech. Every one of your posts seem to be those of a knocker.
Why don`t you just take the hint .... and take a hike - a long way away!!!!!!!!!!!
Quote " Ive dabbled with the usb out of the DSP to PC for direct downloading of the nc files to the inner file list on the DSP, but havnt quite nailed it. the syntek software is not the most stable, plus cant find any help files out there....so its all a bit of a guess at the mo." End Quote.
What has the Syntec software to do with it? The Syntec is a controller that is used on the Auto Tool Changer machine, and has nothing to do with the DSP on a manual tool change machine.
Our Chinese USB sticks that were supplied by Excitech do the job extremely well. In fact we lost the first USB stick and Taney sent over another couple for us to use. In a year and a half - absolutely no problem with them.
Then you try to tell us that your Yako drive is shot. But then it turns out not to be the case. Next attempt - the wires are broken. Sheesh!
Our Excitech has been absolutely reliable.
There appears to be a new " carvinmarvin " that comes along every month or so to try and rubbish our machines - but you all just trip yourselves up. Get a life!!!
Rocket.
Reason: swearing may not be appreciated.
