very cool,
I have a power supply question; can you make a reasonably safe power supply using a ground fault interrupted breaker but no isolation transformer? just a big high current bridge rectifer and filter caps, feed direct from the mains. Use it to feed a synchronous H bridge pwm buck converter for variable voltage output. This would be cheap and flexible. plus the charge on the filter caps would kill you isolation transformer or not.
any thoughts
Amplexus Ender |
