BTW to all of you newbies to solder your own electronic this is a great lesson, I'm not new to soldering circuit boards, I have done quite a few, double check your work, than check and check again. It's SO easy to make mistakes, even if your supper careful, recheck before you add power, if not the end result will be smoke and maybe fire but mostly smoke.
AND RTD (Read The Directions)
