A 1995 Partner 7? Was the control updated?
If it has the original SEM motors with the Tach built in, you should check the cabling to make sure the tach is connected to the control. Since it was recently rebuilt, there could be a slight chance the tach wires were swapped internally or not reconnected properly externally.
DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
