Originally Posted by Pplug I would like to redo the system because it gets clogged with gunk from the reservoir and reduces flow or even stops it completely! |
Where does the gunk come from? I never have that problem.
I do not think the larger tube diameter is needed. At low volume flow the restriction has not proved to be a problem. I have 10 metres of 1/4" tubing.
As flow increases the effect of restriction goes up exponentially of course. If you want it to squirt like a fire hose it will have a huge bearing on it.
Greg
