Insert thread mills | | Jtrav,
I have used Iscar insert thread mills with great success.
They have metric inserts and several different sized tools.
You should have no problem as your hole (75 mm) is almost 3 inchs in diameter. No problem fitting a tool in that.
They will usually help with the program if need be.
