Old 06-04-2009, 06:00 PM
camster camster is offline
camster is on a distinguished road
In NX you can add the Clamp UDE and set it to Auto. Then in Post Builder look in the custom commands for the 4th and 5th axis clamp commands and edit them to output the correct codes. This should output the codes when the 4th or 5th axis moves. You can also use the UDE to manualy unclamp and clamp the axies.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
