Thread milling, can anyone help | | Hi guys
new to CNC zone
But I am hoping you guys will help me
I have been running (setting, operating, programming) a CNC mill for just under a year
The controller is a A2100 which I think is a really cool conversational programming type.
I have had no problems up to now with tapping holes generally being M25 or under which the machine handles well
However I have a job that requires a 75mm dia hole with a 1.5mm pitch thread 40 mm deep.
Thread milling seams to be the answer, apparently! but I do not have any real access to CNC machining experience as I am a project engineer working for an electronics company and this is our only machine and I am the only one with any prevoius "metal cutting experience"
I think I should be using a bore cycle with the speed and feed set to cut 1.5mm pitch or possibly a helical milling cycle But it is the tooling that is my problem
I have been told that you can get thread milling cutters with indexable carbide tips.
Question: can anyone give me the manufacturer (Kennmetal, Hertel etc) and part number of a thread milling cutter
I am from Great Britain so I will not have access to American suppliers
I would also be greatful for any tips and strategies that I could use to do this job, i.e depth of cut, feeds speeds, tool retraction, orientating the tool etc
Please help I am a little out my depth here !!!
regards
jtrav |
