I got no axe to grind here as I've never used or are likely to use LMS but tee nuts can be made to fit anything - slot depths vary - deal with it, just put them in the lathe and turn them down! The chuck adapter I assume is slightly oversized to allow truing to your spindle rotation - its not rocket science to fix - it don't need a skilled machinist to fix, if you can't do it yourself why the hell have you got it? The box labling is weird but an MT1 centre of any standard would be hard pressed to be described as h/duty! Take a chill pill dude! |
