01-26-2005, 12:12 PM
 | Site Owner | | Join Date: Mar 2003 Location: United States
I received this kit http://www.hobbycnc.com/cncpackages/...g/4aupcpkg.htm today. Included with our 3 or 4 axis chopper driver board KIT (4AUPC) are the required components to operate 3 or 4 steppers rated at up to 3A at up to 43VDC. Included in the package is a cooling fan and guard, DB25 Parallel Port Cable, stepper motor cable, hookup wire, fuse holders and fuses, filter capacitor, switch, 35A 600V bridge diode, heat shrink tubing for the motor/cable splices, grommets, labels, ALL hardware, instructions, wiring diagram, and full size template drawings to help eliminate layout errors! Case and 10A transformer are not included. All other components and hardware is included. Only a computer, software, soldering iron, solder, case, transformer, and tape are not.
Everything was very well packed in their own bags. I looked briefly through the manual and found that to be very well written and with very good wiring and hook-up diagrams.
I will upload some pictures tonight and hopfully will start the soldering. Stay tuned...
__________________ Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com |
