  #11   Ban this user!
Old 05-29-2009, 12:51 PM
Hirudin's Avatar
Hirudin Hirudin is offline
Hirudin is on a distinguished road
Originally Posted by macdarren View Post
I ran mine for a short time without the limit switches and I have to say were I to do it again I would not. At the very least you will want to use a tool plate to protect the table. I found while I was first getting things going I had several problems that led to run away. I was pretty careful and tried to keep the work raised off the table some to give me a chance to stop the mill if needed and used some cheap AL plate to protect the table most of the time. I did manage to estop several times when things when wrong, before I drove a 3/8 mill into the table during a rapid reposition where the machine somehow lost it's Z reference.....I then decided it was time to get some limits installed.
Can a limit switch prevent the Z from going too low? It seems like it would only work if all your tools were the same length.
