Smithy has contacted me and offered to pick up the machine and repair it. The relays are bad and not coolant proof, and the casing needs a gasket. It was a month late when they built it, and i think id rather cut my losses at this point then deal with smithy and ez-trol.
Sadly, i have determined at this point that Ez-trol is complete unacceptable in every way, and im better off spending the money and retrofitting it to mach 3 Im upset that im going to have to spend another 2 to 3 thousand to get this machine working correctly but live and learn i guess.
I asked if they would offer mach instead of ez trol, and they said they couldn't do to the required pins and ports the machine uses. I think they really screwed up here and who ever designed ez trol should proably be fired on the spot.
In retospect i should have bought the microkinetics 1236 or a syil c6 or even spent the money and picked up a used haas.
__________________ I don't give a damn if you don't like me, cause i don't like you cause you are not like me. |
