It needs to be a center cutting end mill since at least for the .125 it is a plunge cut completely. Set the plunge speed low. If you cut an inside profile, and leave a disk, you will launch the disk unless there is something holding it down.
Look at the Onsrud cutter site for feeds and speeds in aluminum. |
