Tool sizes and tool changes | | I am milling some .080 aluminum sheet with a large number of thru holes range in size from .125 to 1.0. A couple of questions:
(1) should I just use a .125 end mill for all operations?
(2) for the .125 holes, is it better that I change tools to a drill, or can I use a end mill OK?
(3) for the large holes, can I just do an inside profile, leaving behind a little disc, or is it better to do like a pocket and mill out all the material - these are all thru holes.
thanks for the help!
AM |
