Old 05-27-2009, 06:13 PM
Regnar's Avatar
Regnar Regnar is offline
Regnar is on a distinguished road
You will need 3 things to make and run your machine. Cad, Cam, Controller.
For Cad you could use Corel Draw or any other drawing program, it basically really matters on what Cam will import.
Cam programs can be cheap and free or really really expensive. My biggest suggestion is buy what you need and what you might need in the future. This way you are not buying 5 or 6 different software's.
Now to give some suggestions. Sheetcam, Meshcam, Cut2d, Vcarve, Cut3d.
If all you ever plan on doing is engraving then cut2d and sheetcam will do well for you. One is a little easier to use than the other.
Controllers you have a few options. Other can chime in with the different ones but 2 that I know and have used is Mach3 and Emc2. Mach is free up to 500 lines of code, after that you will have to pay for a liscence. Unless you are going to do stick lines for letters 500 lines doesnt go very far at all. Emc2 is free and what I use. You have to install Ubuntu which is linux and wasn't very hard at all.
For easy cheap and no headaches I would do Cut2d with Emc2. You will not need a cad program.
Eitherway good luck with you search.
