Old 01-24-2005, 07:37 AM
ger21's Avatar
ger21 ger21 is online now
The current Xylotex boards no longer use the J10 and J11 terminals. All unused parallel port pins have screw terminals. But like I said above, you'll still need to add the pullup resistors on a seperate board.
The Xylotex Unipolar board (you assemble) has provisions for the pull-up resistors on the board, which should allow you to hook your switches up directly to the board.
