Ok I have the Walkie Talkie ready to go and I started looking at the G540 and Mach# as far as how to set up the output to the relay and I want to make sure I have it right.
So If I Go to Spindle Setup in Mach3 and enable relays and set M8 Flood Output to #3.
Then in Output Signals I enable Output#3 and set it to Port1 Pin1. I should be getting a short to ground from position 6 on the G540 main terminal block?
Also because my power supply is 48V I am guessing I need to use a 48V relay?
Please let me know If I am on the right track here. |
