Thread: Gear rollers
Old 01-23-2005, 08:16 PM
MrBean's Avatar
MrBean MrBean is offline
Gold Member
MrBean is on a distinguished road
All you've done is replaced the ballscrew with two sets of rack and pinion. Which still leaves your statement:
Originally Posted by Bassbuilder
The problem here is that these polished slides are very expensive along with the pillow blocks.
You still need to use these parts, or buy/build something cheaper.
To extend the machine you still need to add the rails/carriages or ground rod. Whatever you use to guide the linear motion.
The rack and pinion is just part of the drive train. Same as a ballscrew, timing belt or threaded rod.
I don't see that using rack and pinion will save you a lot of money.
Regards Terry.....
