Found the mister in the clearance aisle. Actually it's the same tubing and ballcock valve in the little hand-pumped one, the only thing I preferred was it has a longer tube. Not that I can't add on as much 3/8" tubing as I like but the thinner mister tubing is more flexible and lays on the table near the mill better.
Not sure where it is normally. Could be in Sporting Goods. Actually Academy Sports probably carries something like this. |
