skullworks
So - basically all leading zeros within a G Code MAY be required ie G1 must be G01(allmost all 5020 controls) |
Leading zeros
not required M00 same as M0, F0.001 same as F.001, T01 same as T1
Work coordinates are called using G15 Hxx (01-20) not g54-g59
Tool offsets are called using G56 Hxx not g43 |
I'll agree here
I have no clue what you were attempting with the G30P1 - loose it. |
this is okuma code, telling him to loose it, is like telling him to cut his good hand off, and saying "get used to it ". Suggest you look up your manual, these are reference return points P1 is usually the toolchange point. Don't remove it just because you don't know what it does
Programs end with M2, and an M2 must be found - M30 is not used. |
BullS---M2 and M30
can be used at the end of the program
