Originally Posted by Davedbq I can create a model and convert it to a DXF or a STL file no problem but where do I go from there? |
If you're talking about 3D models, the take a look at Meshcam,
http://www.grzsoftware.com
For 2D stuff, ACE will work, as mentioned. If you want much more control, look at SheetCAM, at
http://www.sheetcam.com
In TurboCNC, under the file menu, choose " Open in Editor". THen, under the run menu, you have several options for how to run it.
