Old 01-22-2005, 11:57 PM
TinkerDJ TinkerDJ is offline
TinkerDJ is on a distinguished road
Turbocnc has an inprogram editor under the files section all you have to do is open the file and then run it. If it has a problem loading the file, then it may have something wrong with it. I use ace converter to convert dxf to gcode and code shark to edit my gcode's. Turbocnc seems to be very easy to set up and use. It has to be on a dedicated dos machine not running in a window. Otherwise it does weird things. I've only run it under freedos. I have a system setup with diffrent partitions one for freedos, one for win98, and one for winxp. Then a partition loader. I think you can download the docs from the website, if they didn't come with the release. Hookup with the yahoo group for turbocnc aswell they have alot of messages you can read and probly help you out.
Have a good one.
Dave
