The problem I have read ,that is the biggest for the beginner/home user, is not getting enough saturation in the fabric which results in a scrap part. |
I can think of two possible solutions. If the glass fabric was pre soaked then the resin may flow through better. OR, What would happen if you had lots of glass fibers mixed into the resin beforehand. Then you should have a uniform mixture. I know they use the latter technique for making glass reinforced concrete, so I cant see why it wouldnt work with resin.
