Mooser, thanks for the reply. I tried a couple things and here is what I have found to date. I checked all three axis with a dial indicator and found that the indicated travels all match the computer. I replaced my cutting tool with a 2 flute 3/16 endmill that miked out right at .187. I setup a test cut including a 1" pocket, a 1" square, and a .5" circle. After the cuts I checked the measurements and the pocket measured .990 square, the square measured .990 and the circle measured .490. I checked the wear values in the tool table and everything is at 0. Is there anything obvious I'm missing here? Thanks. |
