Thread: Need Help! Welding Plasma Table...
Old 05-18-2009, 02:02 PM
tof1 tof1 is offline
tof1 is on a distinguished road
Originally Posted by Dustin407 View Post
Tof1,I understand your problem.. What if you weld up the table, then the 2 x 6 that the rails are mounted to leave unwelded. You can bolt the 2 x 6 to the welded frame below, this will allow you to take both the rails and tube and put it on the mill... The only problem with not welding the 2 x 6 to the rest of the table is, does your design allow you to do this?
That's a good idea but I think it would complicate things. The 2x6 rails will be on their sides (2" wide, 6" tall). The only way warping from welding will throw me off will be if the rail bends in a U shape on the vertical axis. I couldn't see that happening... I'm thinking it will only warp on the horizontal axis (if at all) then I can use shims like Disconnected was saying. What do you guys think?
