Originally Posted by HillBilly The XDI board outputs these signals to the drives. Basically in the side cabinet everything below the terminal and fuse strip is removed and replaced with a PC.
Darek |
So if I understand this correctly, the breakdown would be like this:
Mach2 (setup for MaxNC Waveform data output) -> Campbell breakout board -> X8 connector on XDI board -> SDB -> Motors
Not sure if the Campbell board will work...I definately want the port isolated.
-Brady
