I think this mill is in the wrong forum. After some calculations the mill turned out to be more than a bench top.
Mill Specifications
Spindle Travel................................................. 0 in.
Swing............................................................16 in.
Longitudinal Table Travel..................................17-7/8 in.
Cross Table Travel...........................................7-3/4 in.
Vert. Table Travel...........................................15-1/4 in.
Knee Travel....................................................15-1/4 in.
Head Tilt.......................................................no.
Max. Dist Spindle To Column...............................8 in.
Max. Dist Spindle To Table............................... 18-3/4 in.
No. Of Vert. Spindle Speeds..............................5 Steps
Range Of Vert. Spindle Speeds................120 - 2000 RPM
Quill Dia.......................................................4.0in.
Spindle Taper............................................... MT3
Spindle Size...................................................1.5in.
Motor.........................................................3/4HP
Column.....Heavy Duty Cast Iron Rectangular Box Type
Dimensions L/W/H..............................20in/14in/56in
ht
