Old 05-15-2009, 11:26 AM
H.O H.O is offline
H.O is on a distinguished road
I'm not sure it would work useing sleep in that way because it is only going to be called once regardless of how long you hold the button down.
Exactly, that's what I was trying to say in my first post. The only buttons that has a "while-pressed" kind of function are the on screen Jog-buttons and they are a special case. The Sleep was an atempt to find a possible workaround for you...
Gerry,
Yep, the Wiki seems to be wrong on this. If you don't want to do it I can double check with Brian and then edit the Wiki.
There is a SetUserLED call that you can use to set or reset "your" LEDs.
