Old 05-15-2009, 11:25 AM
PoppaBear10's Avatar
PoppaBear10 PoppaBear10 is offline
PoppaBear10 is on a distinguished road
Gerry,
Yes the Wiki is Wrong on that count, it was written a very long time ago via John Pentice. But, the good news is, if you want you can "Join" and "Correct" the error!!
Open Mach3, then goto Operator->VB scripter, when the window opens,
put in the code: SetOEMLED(13,1) and then do a step through or just hit the "Run" button, it will give you an error saying: Expected =, or something like that........
You could also use the OEM LED code for Output1 as you wanted in place of ULED 1500.........
The really cool thing about mach is the POWER it give to users to customize the Crap out of it!!! There are many ways to do many things. You could even use "Brians" if you wanted to do it as well.
I suspect that the reason that the Wiki hasnt been corrected (btw there are Many other issues there as well), is that editing the Wiki is a pain in the butt, and time consuming.
NOTE: In the Forum section of the "www.machsupport.com", under the subject area called: "Member Docs". I published two documents for the "Undocumented" VB. One is VB Parameters, the other is an extension to the "Mach Specific Subroutines". These where dirived directly from the C++ header file that Art himself sent to me a few months ago, to FINALLY try and get ALL the VB documentation up to date...........
scott
Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
