Old 05-14-2009, 06:12 AM
jimcolt jimcolt is offline
jimcolt is on a distinguished road
Hopefully you have solved the problem....poor grounding can certainly cause bad angularity issues. On my machine I have a ground cable attached to the main work clamp connection...that I attach directly to the sheet or plate that I am cutting. This eliminates issues with bad connections between the dirty slats and the plate. Grounding can be an issue once the slats get a lot of slag...or when you are cutting lightweight materials.
Jim Colt
