Thread: Taig Flycutter
Old 05-13-2009, 11:02 PM
DeusExMachina DeusExMachina is offline
DeusExMachina is on a distinguished road
Originally Posted by escott76 View Post
Not desireable in the Y unless you were making passes in the Y direction. Even then it's only the tiniest bit, you shouldn't have a huge difference in the two sides.
Agreed, I posted a thread earlier about surface finish with a flycutter...same cutter mentioned above actually... Turns out that I did too good of a job tramming the head and the tool more or less stays in contact for a full 360 degree sweep leaving a "fuzzy" finish in its wake.
Before I start fly cutting again I need to very carefully knock the column a few tenths out of alignment (thats going to painful considering the work I did to get it aligned) so that the trailing edge just barely rises above the cut surface.
