I would not weld the frame with the rails installed.If the frame warps you will ruin the rails.Rails could always be shimmed later on if your frame warps.Make sure when you weld you always get every thing squared and tacked.Then add (in welding terms) a strong back to the corners.The more bracing you have on corners the better. |
