I just wanted to let you guys know what's new.
For the past couple of days myself and HU (and a couple of un named guys) have been given the opportunity to look at the latest update/ patch for OneCNC Xp series software. In a word:
WOW.
We have been putting it thru the
wringer, and I wanted to tell you about some of the new stuff. (not all though).
They have listen to user suggestions and incorporated many. With more to come.
There are some new tool path options that are very impressive. Lots of different ways to approach the work zone. And several different choices for tool path styles. New multi logic pocketing and Z level machining.
A new "Tool Path Preview" fuction.
This is the Cat's Meow. A live
"movie" of your selected tool path, complete with tool, cutting your model. As
HU said
"the only thing missing are the chips".
Here you can
"play" your tool paths or step thru them a step at a time. And you can zoom or rotate the model while the
"movie" is playing. This allows you to look at any section close up or rotate to a better view, all with out the simulation stopping. And you can use a solid model or a transparent one. The transparent model allows you to see into say a pocket bottom to really check out what is going on. Too Cool.
Several more tool bars options have been added. All fully customizable.
Lots of "tune ups". Something like 100 items. To name a couple, the auto save is now working right and the facing has been improved.
New tool colors in simulation, every tool has a different color on the simulated model to show what tool did what cuts.
A new Import funtion called: Import - Backplot - (g code ISO format) for importing g code from other sources.
The Verify funtion is improved and is now modal.
We did find some
"wrinkles" but with in less than 24 hours of reporting them OneCNC had them all fixed. Talk about fast.
The release is very close.
