Hi everybody,
I recently aquired a SHM0906 from a company that went bankrupt. They wanted to use the machine for refilling ink-jet cartridges and had a custom-built dispenser head mounted instead of the spindle motor...
Together with it came a whole bunch of stuff, like the original electronics, spindle motor, software, etc.
In the last days, I managed to re-wire everything and I can run the demo-files included in the hand-held controler.
But I can't get the spindle motor to work! The inverter is a
VFD-M from Delta Electronics. The wiring seems to be just fine (see picture), the remote control panel shows some numbers, but the motor doesn't move at all - I can't even start it manually. Maybe the inverter settings were changed?
Does anybody have these settings at hand?
A software called 'Type3 TypeEdit' is included, but it's all in chinese and the version is 4.3. Is there a way to upgrade to an english version? What is the current version? I've seen announcements of a 4.6 and 5.3 version...
Any help would be greatly appreciated.
Regards, Ray
