I read somewhere on the Mach forum that for Mach Turn set the spindle pulley ratio to .1 instead of 1 like on the mill.
Config/Spindle Pulleys.
I noticed the same thing when I tested the C3 board recently.
I have one slot in the disc and Mach Mill outputs up to 6300 rpm but
when I tried Mach Turn it would only output about 300 rpm spinning at the same speed.
Haven't gone down to test it on the Mill yet but it worked on the simulator.
Hoss
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
