Old 05-12-2009, 08:39 PM
mc-motorsports's Avatar
mc-motorsports mc-motorsports is offline
mc-motorsports is on a distinguished road
Originally Posted by NavyF350 View Post
When I put the bell housing under the milling machine I couldn't reach all the holes, as well we didn't have an ideal tool to find the exact centerpoint of each hole because they were unthreaded.
So, would it be better to take a VG block (the engine the transmission comes from) and use it to get the measurements? The lower mounting holes are bolt on brackets that would be simple to fabricate...
I may have solved this myself, well I needed something to redirect my thought path!
You don't have a test indicator?
I would use a block if at all possible, would be easier since you should have more surface area for it to lay flat, vs a trans bellhousing.
MC
