  #12   Ban this user!
Old 05-12-2009, 06:43 PM
Jeff-Birt's Avatar
Jeff-Birt Jeff-Birt is offline
Jeff-Birt is on a distinguished road
The 'VFD' output is a 0-10V signal to control the spindle speed on a variable speed spindle. Unless you add a variable speed spindle motor/drive at some point it is not important.
For the current limiting resistors you use 1K per amp of rated coil current. So if you have a 2.8A motor you would want a 2.8K resistor. The closest you will find is 2.7K, which will work fine. Don't go nuts trying to get it exact. Use a regular 1/4" carbon resistor.
Jeff Birt
