  #12   Ban this user!
Old 05-12-2009, 03:55 PM
Willyb Willyb is offline
Willyb is on a distinguished road
Duality Lathe Arrived.
Hi Guys
I ordered my Duality Lathe on May 5 and it arrived safe and sound (Fedex) on May 11 to Ontario, Canada. It was in good shape and well packaged. First of all the Lathe is placed inside a heavy Cardboard box that is internally lined with a high density foam cut to fit snugly around the Lathe to prevent it from moving around inside the box. The ends of this box are lined with a sheets of Plywood. The top Foam insert holds the Chip Tray (for manual Lathe work) and is the first thing you see when opening this box. After this box is tapped shut a sheet of Plywood goes on the top & bottom with the whole assembly secured with metal band strapping. This complete assembly is than installed in a second well tapped Cardboard box. The package arrived intact and did not show any signs of abused. I will have more when I remove the Lathe.
Willy
