monte55, You didn't mention what the application was. These are not, as keebler33 said, appropriate for spindles. These are simple ball bearings, not much axial support there.
Angular contact bearings are more appropriate. A/C bearings can be supplied with varying contact angles and preloads. You should be able to match proper bearings with your application whatever that is.
Dick Z
__________________ DZASTR |
