Old 05-11-2009, 07:01 PM
rgh rgh is offline
rgh is on a distinguished road
Assuming you are using the spindle with the air balancer, it is normal when you remove the air from the device after shutting down. I use a block to keep it from setting all the way down, and just re-home after each start-up.
