Old 01-19-2005, 03:58 PM
pab pab is offline
pab is on a distinguished road
Question 5 axis control system need suggestions
Hello
I am very new to CNC control system and need to buy a machine controller for a 5 axis cnc router that I am just finish building.
I am not looking for a high end solution but more moderate cost effective option with good technology and open control system.
I have been told to look for a controller that has simultaneous interpolation on all axes and has high block process speeds and look ahead capability.
My plan is to cut larger shapes and contour machining of plugs for Fiberglas moulds and vacuum forming moulds etc. and anything else that comes in the door.
The router is designed to cut at 400 inches per minute. I will start with the machine operating as 3 axis, and in the future go to 5 axis. This router has 10mm pitch ballscrews 30mm dia. on xyz axes. The xy moving table is 4ft by 5 ft and 30 in Z axis.
It will have a 9hp spindle motor probably Colombo. I have OneCNC XR Cad/Cam that would be generating the tool paths in g code.
I have heard about the Mach2 cnc controller and am considering using it. Is their other controls I should look at?
I am not clear on how to put together the control system and could use a little advice.
Could you give me an idea of what the components I would need to purchase. Possibly the names of the better quality components and those that may save me head aches down the road and be easy to install and get operational?
I was planning to use AC brushless servo motors and drives as I heard they work well and presently considering Baldor motors with their Digital FlexDrive2 motor amplifiers. I am open to other suggestions and cost effective approaches. I have heard of gecko but if they are DC servo how would they preform compared to the AC brushless?
I realize I have a lot of questions but I sure would appreciate some good advice.
Peter
