Old 01-19-2005, 07:59 AM
Jan Jan is offline
Jan is on a distinguished road
I've thought of something very similiar, only using round stock attached on top and bottom of the square tubing, and maybe using pulleys as wheels.I think you could then eliminate one bearing, because the round stock is self guiding.
To reduce the amount of play between the roller and rail, use an excentric bolt.
I have a radial arm saw with this same setup, and there's no slop.
