Old 01-18-2005, 09:38 PM
JFettig JFettig is offline
Gold Member
JFettig is on a distinguished road
I recently upgraded my drive box and everything on my mill, new computer(motherboard and hard drive) and I am now having problems homing again, I installed the fix, I took the INI off my laptop that was running, hooked everything up good and the machine will home, but sometimes it will just stop randomly, not completely homed, so I have to home again, sometimes it goes an inch, sometimes half an inch, other times the whole way. Typically when the machine is on the home switches, it moves off and back on, on my X axis where I had the problem first(now on Y too) it would just move a couple thousandths and no more and call it zero. The Y and Z axes do this correctly still.
Is there anyway to pinpoint the problem? I changed the input for the X to pin 15 rather than 12 and then the Y axis acted up,
All I did to the switches is cut the cables shorter, had them hooked up identically.
I want this machine to work right, I have some parts to make this weekend.
Jon
