If they are 3ph brushless (not true AC sinusoidal) , cogging at low rpm is normal. The normal way to control a servo in the torque mode is the motion controller has to have control via feedback generaly in the form of an encoder to close the torque loop, otherwise runaway condition is likely. That is why it is usual to only enable the drives after the motion control has come up and running and is not in a fault condition, otherwise the same thing can happen.
Al
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
