OK, found an interesting wrinkle.
If I change the circle diameter, then the toolpath for the pocket does not seem to update automatically. In other words:
1. Draw circle .500" radius
2. Create a pocket operation on the circle
3. Compute toolpath
4. Modify the circle to have a radius of .750"
5. Recompute toolpath
6. Toolpath doesn't change
What I've found is that after modifying the circle, I need to re-select the geometry for the pocket, or else the toolpath doesn't update to fit the changed radius. Is that right? |
