Old 01-17-2005, 02:48 PM
noid noid is offline
noid is on a distinguished road
I took the liberty of changing your design in the new dxf (It's easier to explain this way). I hav machined a shaft with a flat like you showed with disasterous results. THe shaft after machining was warped alot and was useless. I since then have come up with the design that you have exept using cold rolled steel bar. WOrks great so far.
Any way see the attached file
