Help calculating load on a nut | | Hi everyone,
I need help on how calculate a load on a nut. Basically what I have is a trapezoidal rod with 18mm with 4mm and a 14mm with 3mm thread both of them just regular trap. rods, single start... And both of them with a 1.5 NM ( 15kgf ) motor. Well what I want to know is what is gonna be the load in the nut if lets say the 1.5NM of the motor rotates and press the nut against a wall or something. Like if you would be tightening it up with a 1.5NM wrench.
If someone can help I aprecciate.
Thank You |
